This may be a stupid question but should the landing light, two way switched from the hall downstairs be fed from the downstairs lighting curcuit or the upstairs.
i'd have thougth it should come from downstairs so the two gang switch for hall and landing is isolated from one breaker in the CU and if the upstairs curcuit fails you can still see down the stairs and if the downstairs goes you've probabaly got enough light to see from bedrooms etc. (odviously if both go your stuffed!)
