LANDIS & GYR thermostat
6 May 2004
Cambridgeshire
I have a Kingfisher Potterton Boiler which is controlled by a Landis & Gyr Thermostat (I dont know and cant figure out the model number). It's an old type 24 hour clock.
I have switched on the Central Heating and kept the switch at "ON" with the timer (i hope) set to be on between 4 and 8 in the evening.I dont have any heating at all,i have checked all the radiators and all of the valves are turned fully.I dont think there is an air block.
A.What does Once and Twice mean as marked on the Switch?
B.Any Suggestions?
Many Thanks
I think you will need to give more details of the system you have.
Some systems have only a pump for the CH. Some have 2 motorized valves 1 for CH and 1 for HW as well as a pump. Some have a 3 port mid position valve as well as a pump.
Basically the programmer/timer feeds electric to a room stat. from there it goes to either (a) pump (b) CH motorized valve or 3 port mid position valve and then to boiler/pump.
You can see any of the above can be at fault, in the simplist case it could be programmer or room stat or pump.
:rolleyes: :rolleyes: :rolleyes:
on the timer, once means it will come on in the time between 1 and 4, ignoring off on 2 and on on 3.
twice will come on at 1, off at 2, on at 3 and off at 4
do you have a gravity or fully pumped? does the DHW work fine? if gravity and DHW works then could be pump. if HW doesnt work it could be boiler. or it could be the programmer
May be I use same type of controller.
It has one more switch.
"Press and Slide" is printed near the button.
I would like to know the function of this switch.
Did you figure out what this button is for? Would also like to know.
Doh! I'll have to take myself down to the local plumbing merchants...
I'll save you the bother, it's an over ride switch to override the current on or off time
If for example the heating is currently off via the timer and you use the switch, then the current off time will be ignored and the heating will come on until the following off time where it will then reset back to normal
and Vice Versa
Matt
