laptop problem
18 Nov 2005
when i use my laptop it sometimes just switches its self off????????
Switches off, or shuts down? If the latter then check the power management settings. If the former then it has a fault and you should contact a reputable repairer.
it doesn't shut down it just switches off! if i turn it straight back on it wont load up but if i leave it a while then turn it back on it loads up ok???????
Can you tell us the make, model, processor,OS (xp?) etc..
Does it just switch off when the fan has been running fast or when you have left it idle for some time??
:confused:
it normally happens when im the internet.. its a toshiba with windows xp home edition..
intel celeron 2.6
What anti virus and firewall are you using ?
Does it turn straight back on ?
Does it feel unusually hot ?
Do you see anything in the Windows event logs around this time ?
Did you buy this new and has this always happened ?
Is this still under warranty ?
Are these questions ever gonna end ? ;)
norton anti virus not sure what a firewall is......
it will turn back on but wont load up if i turn it straight back on after it has just cut out, but it will load up if i leave it a while 15 20 mins....
it is quite hot underneath not to sure if this unusuall...
not sure what the windows event log is.....
i did get it new but it as only just started to do it....
it isnt under warranty.....
