laptop with no serial port
2 Jan 2007
Berkshire
Hi guy's,
As mentioned I need to add a serial port as when using an service checker for some strange reason USB is always tricky and yesterday we tried for 2 hours checking port settings and ending up failing. It's a known issue with this piece of kit and the manufacturers engineers simply won't use it on USB for that reason.
So my HP laptop hasn't got a serial port -is there anything I can do or add which will give me this urgently needed option??
Cheers
Richard
Just be aware that USB/Serial adaptors don't always work correctly. Sometimes there is a timing issue and the devices won't handshake properly.
Just to bring you up to speed..
I read the Maplin link and thought "download the drivers for this device" This got me thinking it was more than just a lead. I pondered could the problem be that I'm setting it all up then switching it all on?
So I plugged in the lead and let the laptop 'find' it. THEN I pluged in the device (Checker from Daikin air conditioning) and volia works first time every time!!
So many thanks for all those who helped :)
Cheers
Richard
