edit: sorry.. used wrong term in header..hole needed through end of the threaded part of the bolt (shank is the non-threaded bit next to the(hex) head isn't it?)
I want to secure double wooden shed doors in addition to the normal locks...especially if away for a holiday.
I want to put a slightly angled bolt (with a hole for a padlock in the end) from the inside of the shed ..so it goes through the "fixed/internally bolted" side of the door frame so that the second "outer" door which overlaps the fixed one when closed (with suitable sized hole drilled in it) can close over the bolt ..so both doors have the bolt going through them....than a good padlock through the hole drilled through the threaded end of the bolt . Bit hard to explain without drawing a diagram!
I'm sure I have seen these somewhere before but I have looked round the net for half an hour with no success. I have found bolts where the hex-head is pre-drilled (.e.g for a wire) but I want one where the threaded part of the bolt near the end is drilled to put a padlock through.
Anyone seen such a thing for sale?..otherwise I guess i'll have to find someone to drill a suitable bolt for me as I don't have a drill that could do that job.
thanks for reading
thanks for reading
