large bore barrell pipe
29 Mar 2009
Hertfordshire
Hello, could anybody please advise me on the jointing of larger bore barrell pipes (1 1/2" and upwards) I usually work with copper and small bore barrell and just need to know if the jointing method is the same for larger bore barrell pipes.
ie; threading the pipe, wrapping in hemp and jointing compound and turning on the fitting.
Any advice or comments would be much appreciated
Thank you
might be a scottish/english thing but what is barrell pipe. is it M.I (malleable iron), if so pipe vice, set of stocks n dies, tin of ronol, cut, screw, boss white ( gasseal if gas pipe) hemp, fittings on, tighten with a pair of stilsons, bobs your aunties fanny.
Hemp? I thought we had moved on to teflon tape, unless it is a longscrew
It would be nice to know what's going in the pipes, as the jointing will be different.
Loctite 55 string is universal.
Gas over a certain size has to be welded and flanged.
For Heating, boss white and hemp is still the best.
I think you are talking about one wrap gas tape, only use one wrap no jointing ( if pipe carrying gas ), Rocol Gaseal only,no one wrap PTFE (if pipe carrying gas), if pipe carrying lphw cannot beat boss white and hemp,been using it for 25 years without a problem. A longscrew!!! its the 21st century brother. Larger pipe carrying gas may well have to be welded & strength tested,purged,tightness tested.
Thanks for the tips guys, much appreciated.
By the way, they are heating pipes in a school
Loctite 55 for me all ady long.
Which is kinda of a shame cos i love the smell of boss white.
