Hello.
This is really a follow on to a question I asked yesterday about a Leaking joint between toilet and Waste pipe. I have now managed to dig out the old filler (looks like putty). I am now left with a cap around the glazed porcelain toilet pipe and the lead waste pipe (porcelain pipe pushes into the lead pipe). This gap is about 1/2" by 1/2". I obviously want something that will stop leaks, fill this gap and will stick to porcelain and lead (fairly clean, but probably still a bit dirty) and will dry in wet/damp conditions (water leaks from the gap when the toilet is flushed, but only a few drips.). Personally I would think something cement based? I do not want to fill this gap and then find the toilet still leaks, as I would probably not be able to dig the filer out again.
Thanks for help.
Paul
Thanks for help.
Paul
