Large crack between interior (party) wall and chimney breast
7 Feb 2016
Hi all,
I've just bought a 1950s semi which is built from concrete blocks (not mundic I hasten to add!) and I started stripping the wallpaper last week. When doing the living room I took the wallpaper off from around the fireplace and revealed a crack running down the left side of the chimney breast, between the wall and where the chimney breast joins. It is pretty deep and I can see there is a bit of a draught coming through (!). The crack itself is approx 5-10mm wide.
I've done some googling but can't find any info about what might have caused it. The fireplace has been blocked off and currently has a gas fire installed (with a gas cowl on the chimney stack) and I can't see any signs of damp; nor are there any upstairs or up in the loft. There has been some (fairly shonky) repair work done to the chimney in the loft but I have no idea if the flue itself is lined or suchlike.
There is a small amount of cracking to the top of the wall/chimney breast on the right-hand side, but it is nowhere near as bad as on the left.
Here are some pics so you can see the extent of it. I am concerned mainly due to it being a gas fire and therefore there being the possibility of CO escape.
Any suggestions or ideas gratefully received! Or even who I should contact about this (specialist builder/chimney expert). Many thanks.
You'd be better off posting this question in the "Building" forum below. "Your Projects" is for sharing information about projects, and not for questions (as it says at the top).
Cheers
Richard
