Large garden room/summer house on part paved base
31 Oct 2015
We currently have a 3m x 3m concrete base at the bottom of the garden when an old summer house stood when we moved in. We would like to build a more modern style, larger garden room/summer house (self build, styled with the cedar cladding on the outside and bifold doors to the front), but would like it to be 6m wide x 3m deep. Half of it would be built onto top of an old patio, would this be suitable?
was thinking a 6m x 3m concrete base (4" deep) right across the current base and patio?
Any tips or pointers greatly appreciated
You can do a concrete base, although that's an expensive way to do it compared with a timber base. Are you going to be keeping within permitted development limits on height, or submitting a planning application?
Thanks ivixor, going to stay within permitted development so under 2.5m high. Could i do a timber base straight on top of the current half concrete slab/half paved area? Would the timber base go straight on top, or anything inbetween with a DPM/sheet?
You need to have the timber base elevated so there is ventilation underneath, i'd say 10cm is a good target for the space. For mine I just placed the timber on concrete blocks, with a DPC between them. Where the building exceeds the concrete slab, I'd pour a footing of concrete for the block to rest on. For 6x3m you'd probably end up with 8 blocks around the edges, though this depends on timber size.
Thanks guys
big-all, the whole lower garden area is patio (and the part concrete base thats flush with the patio), do i take that as my ground level? If not, how would i know the natural ground level?
At present, from patio level up i have about 6" of concrete gravel board, then standard 6ft fence panels
