Large manhole cover
19 Dec 2015
Hi all
I have a large 900x600cm inspection chamber that I need to get a cover for. It's in the garden so no heavy loads.
900x600 covers are very expensive - is there any good reason not to use two 600x450 covers next to eachother?
The 900x600 are £200-300 which is a lot for something that's in the corner of the garden, and will never have any traffic over it. Maybe a couple of concrete slabs would be a better option
What is the purpose of the chamber and whose responsibility is it?
It's just an inspection chamber for the foul waste drain before it leaves my land - my responsibility. It's an old Victorian trap - can get blocked from time to time. Previously had been buried, so have kept open for future access. About 80cm deep.
As Hugh says you could cast a slab over it with a standard hole but I think I would simply stick a bit of PSC lintel across the middle and a course or bricks rould the perimeter then put 2 standard c&fs side by side.
Alternately you could bed a few bits of lintel to close half the hole and just have 1 cover (probably the easiest option)
If you weren't having to open it regularly, a 3x2 paving slab would be fine
