I am planning on building a shed at the bottom of my garden in a small area of woodland. I want it to last at least 10 years. There is a clearing in the middle of a group of 5 large trees and some smaller ones.
My shed will be 6.6 x 4.2m with a 2.5m eaves height and a dual pitched roof. The area is on a slight slope. Ground is about 8 inches higher at the far end of the shed. Also my plot is only about 2ft from a small tree and there are a few overhanging branches. But this is all I have to work with.
Currently I am working on the base and would appreciate some input on whether I am going about it the right way.
I have excavated to a depth of about 6inches at the low end and 14inches at the deep end to get it level. There are still a few roots deeper in the ground but I don't want the shed sitting any deeper.
I plan to build a shed base consisting of solid concrete blocks with 4 x 4 wooden skids placed on top. I went for this design as I want a wooden insulated floor and didn't want a concrete one.
I plan on making 9 rows of concrete blocks running the length of the shed, 6.6m. They will be placed approximately 0.5m apart from the block center. I'm going to support these blocks with 3inches of hardcore followed by 1 inch of sand, then damp proofing, then 1 inch of mortar to hold the blocks in place.
I'm not going to hardcore and sand the whole area, just the strips where the blocks will be sitting. Once the hardcore is in place I'm going to refill the gaps with soil then compact the whole lot down.
Does anyone see any problems with this plan.
Mainly do you think the damp proof will keep the roots back.
Is the hardcore and sand layer thick enough.
Will just placing hardcore strips with soil in between be sufficient.
Is my block/skid spacing close enough.
Thanks for your time and any advice.
