Trying to overcome a plumbing routing issue for bath and shower waste, caused by a wacking great steel I beam. Can't go under, as the ceiling mounts to a wood casement and it's too early in the run to go that low. Can't go over, as that's just below the floorboards.
Can't box the pipes in as there is window that goes to floor level between the bath/shower and the soil stack (the window spans 2 storeys in a converted church.
I've got two solutions:
1. Build a raised floor across half the room that in effect gives a giant box that enables me to get over the I beam. I've embarked on this adventure, but it seems like overkill.
2. Drill two x 43mm waste holes through the web of the I beam.
I had previously discounted option 2 without too much thought. Option 2 might be feasible though if I could a) find a drill that large to cut through the beam, and b) if doing so would be permissible under building regs.
I'm away from home at the moment, but the I beam is huge - probably 6" wide on the top and bottom, with possibly a 10 or 12" web (working from memory). If I could physically achieve it, could option 2 be a permissible option? It would be aesthetically much better and would uncomplicate a host of other issues I face with the raised floor option.
