I've been scouring these forums for quite some time, and finally decided that posting my question may yield a better answer to my particular problem.
I have recently had a new central heating system installed which consists of a Vaillant 438 with 250l indirect Megaflo. It is a 3 zone system, with separate upstairs, downstairs and hot water. There are 18 radiators currently installed, rated at 33KW (9 rads upstairs, 9 downstairs). I have range rated the boiler to 30KW due to struggling with S53. This is an aside question, but I am still confused as to how to range rate the boiler to cope with one zone open (eg. upstairs) or all three zones open.
On the whole, the system is working ok, but there is a single radiator upstairs which does not get as hot as the others. Possible one or two others upstairs not as hot as the others either. They are probably the furthest away from the pump. I have a 15/60 pump before the zone valves on setting 3, and have added a second 15/60 pump on the downstairs circuit on setting 2, after a rad downstairs was struggling to warm up also. I've been advised by a couple of RGI's that I should have a single 25-80 pump installed, and that should be sufficient for the whole house. Having made the mistake of spending money on bad advice previously, I thought it'd be prudent to do some research into how to calculate pump size, and found an excellent post here by ChrisR:
//www.diynot.com/forums/viewtopic.php?t=19661&start=0
Im not sure exactly how I work out what my "head" is.
Btw, Ive tried to balance my system over the last couple of weeks, tweaking it here and there, which has resulted in every radiator warming up much better, but still that single radiator upstairs struggles.
My question is, what steps should I take to try and resolve this. Finding someone as knowledgeable as some on this forum to come and advise me what to do has proven impossible. Every RGI ive called seems disinterested in doing any calculations, or justifying why they recommend a 25-80 instead of a 25-55 or 25-100. It doesnt instil much confidence, but having said that, their "gut feel" could prove to be precisely right. The Grundfos 25-80 seems to sell for almost £300, plus I need somebody to remove my second pump, and replace my existing 130mm pump to accomodate the 180mm. Hence I want to be sure this is the right approach.
Thanks for any and all advice.
