- Joined
- 13 Apr 2006
- Messages
- 150
- Reaction score
- 0
- Country
Hi There
TIA for any help.
The combi feeds 6 rads on the loop, the last one is in the living room and by far the largest rad in the flat. A couple of months ago the l/r rad went cold. I then found for whatever strange reason the installation was completed with the last rad being fed by 10mm wheeras the rest is 15mm.
I have cleaned the radiator, changed the valves (including 1trv), the boiler is working fine, the hot water is fine, the central heating is fine, apart from the living room radiator, which is slightly warm on and around the trv, but the rest is cold including the pipe on the lockshield.
Any ideas would be appreciated as I am about to cause some major damage, getting to the pipes and getting shot of the 10mm feed.
Oh and I have also bled and refilled the system at least 3 times.
TIA for any help.
