latex or water based compound
15 Nov 2003
From what i have found latex self leveling compound is expensive.£50 a go.Does anyone know if you can get it cheaper.Also can water based compound go on top of latex.If this is the case its much cheaper.
+/- 7mm in places.I,m also tiling between 2 rooms.The kitchen floor is dead flat.The utility room is not.Also where the 2 rooms join the floor bumps up a bit to join the kitchen.You wouldn't know unless you put a spirit level or straight edge on it.
