Does anyone know where I can get Latex or a similar floor levelling compound in the Medway, Kent area? I need to level my cellar floor and in places it's up to an inch deeper than in others.
Also, to cover an 11 foot square floor from nothing to 1 inch thick how much Latex will I need to buy?
In case anyone is interested in the details:
I have a cellar approximately 11 feet square. There was some damp problems, as you would expect, so to get around this I first cleaned all the walls of any of the previous renders and stabilised any powdery surfaces with a strong PVA solution.
I then painted three coats of bitumen-based paint on the walls down to ground level and up to the joists of the floor above the DPC level.
I then used premixed waterproof tile cement to glue plasterboard to the walls.
The floor was laid with a DPM then ready-mix concrete was laid above that. (Unfortunately it is none too level) The bitumen paint was used to create a seal with the DPM.
To ventalate I installed a 9 inch extractor fan (OTT I know but it actually does an adjoining cellar of similar proportions and so far (about a year on) it is dry as a bone!
