My loo pan is not fully flushing, the front area is being missed. I reckon, either the feed pipe from the cistern is partially blocked, or there is a build-up of scale where it enters the pan. Would it be feasible, to clear any scale by blocking the point where the flush water enters the bowl, and then fill the flush-pipe in the cistern with something to dissolve the blockage?
thank you,
not had such problem before.
thank you,
