This might be a daft question and I'm probably missing something obvious here but would it be ok to lay may new carpet then have the skirting boards fitted afterwards or would this cause problems?
How are you going to fix them to the wall?
IMO, fitted carpets which run under skirting look so much better than ones which butt up against them, and if they are painted then it's so easy to slide a piece of card under them to protect the carpet.
a carpet is held taught by the gripper.
the tuft of carpet remaining is tucked away by friction pressure between the deliberate gap left between the gripper and the skirting.
FIT SKIRTING FIRST.
I too would like to know the answer to this cos am in the same situation.
The problems I can foresee are that if grippers are used, carpet put down then skirting attached, how are you supposed to get the carpet out and replace it without pulling the skirting off?
Also the combined height of underlay, grippers, carpet will make the skirting 15 to 20mm higher on the wall. Will this look odd?
A lot will depend on the decorator you have but many prefer to at least prime and undercoat first, if nothing else it's easier on their kneesWhat about painting before fitting?
What do you folks suggest?
I have stained & varnished before fitting which was fine, but I found that painting before hand means leaving for several days as the paint is still soft or several days & easily gets mucked up - requiring repainting.
