- Joined
- 31 Mar 2017
- Messages
- 35
- Reaction score
- 2
- Country
I bought a lay z spa, and contrary to what I was expecting, it's potentially not quite plug and play. According to the manual "it is recommended to arrange for a qualified electrician to connect the spa pump to an equipotential bonding terminal using a minimum 2.5mm² solid copper conductor"
I've been reading about equipotential bonding and, at the risk of massively oversimplifying, I understand that they're basically saying it's "recommended" to be connected to the common earth of the house, like at the consumer unit or supply.
My question is this, would it be sufficient to clamp some copper cable to some copper pipe that is already supplementary bonded or (this might be completely daft) connecting to an earth bonding plug like this (https://cpc.farnell.com/coba-europe/hr000009/hr-earth-bonding-plug-uk-yellow/dp/SA02447).
Ideally I'd like to avoid getting a spark in and some permanent modification just for something that's going to be in the garden only occasionally.
Appreciate any replies and all opinions!
