- Joined
- 13 Jan 2016
- Messages
- 253
- Reaction score
- 2
- Country
Hi, I’m after some advice & tips on laying 1800mm lengths of engineered wood flooring that is click system.
I can cut it but the cut end would have to be laid against the wall, once cut it cannot be joined into the next length.
I’ve done a bit of reading & watched some you tube videos, lots of differing advice on which end to start, left or right, far corner etc.
It’s my own house. First room is just under 4.6m long. So that equates to 2 full lengths (1800x2 = 3720) & a cut of 870mm.
Then when I lay the next row do I just do the same again but put the cut up the other end. Then repeat that pattern?
Any other pointers would be greatly appreciated! Thanks
