Laying a thin wetroom screed over existing concrete floor
29 Jul 2010
Hi, wasent sure if this is the right topic but surely people experienced with rendering walls should be able to help me here.
I am about to lay a semi-wetroom screed over a previously poured concrete floor. When I say "semi-wetroom" I mean there will be a wetroom shower area but due to the small area (86cm x 96cm) it will probably still need some kind of shower door.
I have already removed some additional material from around the drain to allow for a thicker screed but it will still be as thin as 1cm in places. I am aware a very thin screed is prone to crack but given the very small area and the fact that the whole screed will then be tiled with large cut tiles, I was hoping a good job of bonding the screed (PVA + Cement slurry) to the existing floor will be sufficient.
Does anyone have any advice how to ensure a thin (between 2.5 and 1cm) screed (covered by large tiles) does not start breaking up?
Cheers in advance.
Why bother with the screed just use waterproof tile adhesive.
