Basically i have a slab of concrete in my garden which i would like to lay decking over.
The slab is 150mm below DPC so i can't really raise it much, and being 8" deep i dont want to remove it.
Anyway, can i lay the deck joist's directly onto the concrete, or do i need to put DPC under them to sto water from rotting them out to fast? Also can i then fix the joists to the concrete or should i just rely on the weight of the wood to hold it in place?
Also as the joists will be 4" plus 28mm deck boards i'm going to come above DPC level. I plan to leave a gap from the house to avoid damp issues and avoid fixing a bearer to the house. What kind of gap should i leave? I was going to leave about 50mm do you think it is enough?
Cheers in advance, Sam
