Hi all,
I have a patio outside my french doors which is built upto the same level as the internal floor. the garden is sloping away from the house, so the far end of the patio is about 0.7 metres deep, the whole patio has a small wall built around it. I am lifting the patio and getting rid of the backfill etc which is in the built up area to expose the air bricks and to eliminate a drainage problem.
My question is this: I plan to lay the deck at the same level as the patio was previously with nothing underneath the deck. This should enable air to flow underneath the deck and ventilate under the floor in the house, i hope. I'm using 4x2 inch timbers as support to lay 38mm deck boards onto. I'm fastening the support timbers onto the internal faces of the built up area using joist hangers. What is the maximum space i can allow between support timbers?
Does this all sound ok?
