Its the first time I am going to attempt to lay laminate floor, however I have now realised that the room is massively unsquare.
At one end it is 2000mm and at the other it is 2200mm. The door at the left hand side (as you look into the room) on the 2200mm side. The straightest wall is the one on the door side but it is still far from straight.
Couple of questions:-
Which way should i lay the floor?
Where should I start?
When I lay the boards should i trim them at the same angleas the wall so they boards all lay straight against the wall?
If you can give me any advice I will be most greatful.
