Laying Laminate on Screed
5 Nov 2008
Im going to lay laminate flooring on concrete screed in my porch.
I understand that I have to put a membrane on the floor.
In screwfix they sell: 1000 gague DPC and 1200 gague DPC.
Thay also do 300 gauge polythene vapour barrier.
What is the best to use?
I plane to go DPC then foamanels then the laminate.
Many Thanks
Your flooring supplier will have underlay with a built in DPM. if your flooring such as pergo has underlay built into it, then 1000 gauge DPM is fine.
If you mean foam panels ?? then your building a trampoline !!
All you need is DPM underlay and laminate flooring..
Many Thanks
