Some background first:
At some point next summer I’m going to lose the room I currently use as a music studio (as I have another baby on the way) so I want to build a decent music shed at the bottom of my garden. Soundproofing is going to be important, so I’ve decided to go with a brick/block cavity wall construction. I’ve got a bit of money saved up for this, but I'm hopefully going to be doing every aspect of the build (except the electrics) myself in order to keep costs down. I’ve got a reasonable amount of experience with most things I’m going to have to do, but my experience of bricklaying is pretty much limited to building a few walls and raised beds etc around the garden. I know enough to do a nice job of it, but I’ve never done a cavity wall.
My question:
I’m currently at the design stage, and trying to draw my shed in Fusion 360 (maybe not the best software for this but I use it in my day job). I was planning to use 300mm wide trench blocks in the foundations and I’ve used a brickwork table to design the outer walls to an exact number of bricks to keep things neat.
My issue is that this leads to dimensions for the internal block walls that don’t work with full sizes of blocks, and I’m not sure what the correct approach is in terms of where I should put any cut blocks along the wall. I understand how to do blockwork corners to maintain a stretcher bond, but if I have to cut blocks to make my walls the right length then what’s the best approach to lay them out? Also do the perps on the blocks need to line up with the perps on the outer skin of brickwork?
I’ve found various documents online relating to laying out bricks, but nothing useful on laying out blockwork.
My shed will be small enough that I won’t need to involve building control, so I’m sure I could just bodge it, but I would still prefer to do it in the proper way (whatever that is).
Any help much appreciated.
Cheers,
Jamie
My question:
Cheers,
Jamie
