I have a bit of a new project and I'm hoping I could gather some expert tips while I'm still in the planning stages as I've seen some contradictory advice.
I am moving to a new build and want to install parquet on most of the ground floor using
https://www.flooringsupplies.co.uk/..._solid_oak_rustic_parquet_smoked_oil_flooring
It's a prefinished product, any experience of this? I think it will need a sealing layer at end but no staining or sanding.
A couple of initial items, I've had various other flooring suppliers warning off parquet in a large living kitchen. Their reason is moisture and temp changes, maybe I'm naive but it's not a commercial kitchen, it's not going to be any hotter or wetter than any other room. Any thoughts on this?
The house isnt finished yet, and the first thing I needed to do is moisture test the concrete floor, I'm hoping this will be ok as it's been down for months and the house has been watertight for quite a few months as well.
I'm assuming that the concrete will be ok but not great so banking on having to put down a sheet of dpm followed by 6mm ply to level it off.
Is this ok and should I install the ply tight or leave expansion gaps between boards, I plan to nail direct to concrete.
I'm then gluing the flooring to the ply in a herringbone pattern, planning on double block border following the plunge saw border technique that seems popular here with skirts refitted on top.
My main issue is that I have to workaround a fitted kitchen that can't come out. I can obvs take out the baseboards and recut these so that the flooring goes under the kitchen units (but I won't be going right to the wall. The tricky bit is the end panels. Should I just block up to and around these then cover the edges with sealer as I'm not sure if I can get them out or how neat it would be to try and cut with a multicutter or similar and block under?
I also wanted to incorporate a brass strip between the herringbone and the double block edging, I found this, but not quite sure how to install it.
http://kirk.co.za/product/brass-flat-bar-25x3mm-mill-finish-brass-2-5m-length/
Any thoughts on any of the above would be greatly appreciated.
