Laying slabs against the house
21 Jul 2010
Bedfordshire
Hi
I am laying slabs on an area to the side of the house, have dug and laid hardcore to about 2.5 bricks below DPC so slabs will sit around 2 bricks below DPC (old house so slate DPC)
Should I lay the slabs right up against the brickwork of the house or dig down 6 inches and lay membrane and stones to create a sort of french drain around the house so the slabs sit about 4 inches away from house?
Hope this is clear
Any advice appreciated
Many thanks
outside levels must be 150mm below dpc because of splash,imo if you leave a small channel and back fill it with shingle then i see no problems with doing this?
So long as your paving slopes away from the walls then just lay up to the house. It looks better and you wont have to keep picking leaves out of the gravel.
Thanks guys
Have decided to lay right up to the house - just about to lay some lines to get a fall towards the garden
