I'm about to lay a bamboo strip floor onto a concrete surface. The suppliers recommended that I glue it down and so I've ordered all the stuff to do that.
Having lifted the carpet, I've discovered that the little bit of floor I previously examined is good bare concrete, but much of the floor shows signs of once having had plastic tiles with patches of what seems to be old adhesive. It's medium grey and almost as hard as the concrete. The thickness is pretty minimal, less than 1mm and it's stuck on very well.
Following advice found here, I was intending to use a water based floor levelling compound before laying the floor. What should I do about the patches of old adhesive ?
Can I use levelling compound over it, or does the adhesive have to be removed first ?
If it has to be removed, how do I do that ?
The skirting has been removed and there are small gaps between the floor and the walls. What it the smart way to stop the levelling compound running into those gaps ?
