I need to fit an LCD tv to the bedroom wall.
The tv is a 26" which weighs 8.6Kg.
The wall is lathe & plaster, & I can get to the other side of the wall as its in a cupboard.
I was thinking of making a sandwhich using 6mm ply.
My plan is to have a piece of ply about 12" x 12" on the outside wall & a piece on the inside about 18" x 30", these would be held together using coach bolts.
Then fixing the tv bracket to the outside piece of ply.
The only part I think maybe a bit weak is using 6mm for the outside as this will then have the tv bracket fitted.
Would appreciate some views.
