I have a wall mounted lcd tv in my conservatory and I'm wishing to hook this up to a dvd player. The problem is the tv power flex is hidden in a cavity stud/plaster wall along with the coax feed. The actual lead (kettle style) which plugs into the tv is wired up to a duraplug style 3 pin in line male plug which in turn plugs into the female duraplug, the flex of which is in the cavity as mentioned and comes out just above the skirting getting its power from a four way extnension which feeds my pc desk. Is there a way of getting a signal from a dvd player without having an ugly scart lead trailing across the wall. I was thinking of one of those sender units, but the problen here I think will be getting power to this on the back of the tv. I suppose I could discard the duraplug for a two way trailing socket, however there ain't a lot of room behind the set and bracket.
Any ideas anyone?
Many thanks.
Any ideas anyone?
Many thanks.
