I have just identified damp areas on lounge ceiling and 1st floor bedroom floor all directly underneath our dormer window. A local roofer has been round and identified that:
1: The dormer window has NOT been protected by lead soakers on each side
2: The dormer window does not have a lead window tray underneath thus causing felt to be visible and exposed to the elements
3: Possibly (yet to be confirmed) the files on each check do NOT have any form of underlay/felt
4: Also the lead flashing on either lower side of cheeks has been done in one long strip of approx 1.5meters in length.
Insurance inspectors are due round soon for visit. The house is only 4 years old and this is causing great concern.
I have been advised by 3 x professional roofers to insist that:
1: lead soakers are placed on each appropriate end. addditionally for these to be installed correctly the tiles and valleys on each side above to be removed - lead soakers placed and then valleys and tiles replaced
2: Removal of dormer window and place lead window tray underneath to seal areas directly underneath and to either side of window.
3: Remove cheek tiles - install felt/underlay and replace tiles
4: Remove current lead flashing on each lower end of checks and replace with lead at intervals of 18ich secured underneath the tiles and then overlapped.
Sorry this is a lenghty note however I am at this point doing some reasearch and would value any advice.
I am also going to insist that they remove plasterboards etc in bedroom to gain access to the area where the water has been enrtering property to check for long term damage.
I would be grateful of any advice from anyone as I`m sure you can apprecitae this a great concern with such a new build property
thanks
thanks
