I am replacing the lead on a mid terrace property and want to use Ubiflex instead of lead. Can anyone advise me how to attach it to the neighbours lead on either side? The reason for not wanting to use lead is potential theft.
Perhaps you should contact the makers or a supplier like angel plastics and explain your purpose - there might be transitional adapters just for this useful material, or a recom. method and adhesive.
Or, merely shape it to adapt to the lead, and use a quality silicon - this arrangement will only have a limited life at the joins.
[EDIT] found the stuff
http://www.shell.com/home/content/bitumen/products/shell_tixophalte/
Oh and you are using the thick code 4 equivalent of Ubiflex and not the thinner one as thinner one not designed for lining gutters.
