Lead pipe to copper adaptor?
15 Sep 2009
Cheshire
What's the best lead pipe to 15mm copper pipe adaptor / coupling to buy.
I've used one of the ones from Screwfix and it keeps leaking!
Thanks.
Leadloc.
If you have trouble with them then you aren't using them properly. Or you have the wrong size.
I have NEVER had a problem with these.
Even on manky lead.
Although really you should be taking all the lead out now.
It will be a 7lb or 9lb lead lock, as the lead pipe normally came in two thicknesses. Should cost less than a tender for either.
1/2" 6lb; 1/2" 7lb; 3/4" 9lb were the common sizes.
If it is 3/4" 9lb Lead-Loc only do that size in 22mm. It will need reducing.
I got one today from PTS thanks.
£15.69 though! It was leadline not leadloc.
