My question is about fitting lead slates, for either stack ventilation or vertical boiler flues.
Does a lead slate in these situations fit over the roof tile where the pipe/flue passes though (i.e. with a hole cut in the tile), or does the lead slate completely replace the tile?
Some lead slates look as if they have the tile under them, some look like there is nothing under them.
If you do cut the original roof tile, to pass the pipe/flue through, is an angle grinder best?
Hope this makes sense!
