Lead to Copper Compression leaking
29 Mar 2005
I have cut a section of lead pipe out to put in a new stop cock to rejoin I took the sectionto the plumbers who told me I needed 6lb 15mm cooper to lead connection (the package doesn't say lead loc is that the better make) one side seems to be okay but I have changed the side 3'x and there is still leakage it appears to be coming from both the lead connection side and the copper side HELP!! what can I do to stop this leak
first thing is to clean the lead and remove any indentations.
Try the "Philmac" universal connector
click
Thanks 4 replies
tried PTFE tape
Do it all do U know if this connector is widely available in plumbers merchants I have U tried it thanks
Jewsons and must merchants should have them.
Yes have used them loads of times, including an old rusty steel pipe
Plumbcenter do Talbot similar things, they grip/seal anything.
If you have a leak at the copper end as well then that would suggest that you have overtightened the fitting.
Get another lead loc connector and cut a bit more off the lead pipe so you have a decent end to work with before starting again.[assuming the end you are working with is all chewed up]
Disassemble the new fitting and re-assemble on the lead pipe in the correct order as you go. That way you can make sure the the pipe goes all the way into the fitting.
Further to last
Those philmac fittings are the biz but if you dont have a decent bit of pipe to work with you are still likely to get problems
Thanks 4 all the replies the leak is very minute so haven't tried to remedy it yet will try one of the alternative fittings that have been mentioned
Will keep U posted Thanks
Thanks 4 all the replies the leak is very minute so haven't got around 2 trying to fix it will try one of the alternative fixings mentioned
Will keep U posted THANKS!
