I want to repair an ancient joint between a 15mm copper pipe and an 18mm lead pipe.
Yes, it is 18mm and not 22mm. I've measured the diameter with calipers and the circumference with tape (and multiplied by 7/22).
I've been told I need a Leadloc or Leadline compression fitting, but I don't understand the sizes, and my local Plumbcentre wasn't helpful.
I was told that a 1/2"x6lbsx15mm Leadline would fit, but the "lead end" and the O-ring are both clearly 22mm.
What does 1/2" refer to?
What does 6lbs refer to?
(The 15mm I understand!)
Does Leadloc have a wider range than Leadline?
Is this whole project hopeless?
The 18mm lead pipe eventually joins to a 22mm lead pipe, so I could cut out the 18mm section completely, BUT the only bit of the 22mm pipe which I have access to (without digging up concrete) is curved, with a radius of a couple of feet. Can a Leadloc or Leadline be fitted onto a curved section of lead pipe?
