Leak finding in a drain - drain Dye dilution help required
10 Apr 2012
Yorkshire
Hi
I have a damp under stairs cupboard which I suspect could be from a leaky or cracked drainage pipe. I was planning on using some drainage dye to determine if this is where the water is coming from.
I have seen some on Screwfix but the instructions for use do not really make a lot of sense to me:
http://www.screwfix.com/p/monument-tools-flourescein-drain-dye/31595#
Can anyone explain how i dilute this dye for use.
Many thanks in advance.
Mandy
I just mix the powder up with some water until its a bright colour.....its meant for use in tracing drain directions really - I'm not sure if the damp would show as a colour, if at all.
John :)
John :)
Thanks John, that is what concerned me some what too, maybe i will have to contact the manufacturer to see if this is the tool for the job.
