Leak from chimney stack
5 Feb 2014
Hertfordshire
A couple of months a go I had workmen in to look at my chimney stack which seemed to be leaking. They replaced the flashing and tidied up the brickwork around the chimney. With the bad weather recently, in the back bedroom of the my house a damp patch has reappeared. I thought when getting the flashing replaced that would be the end to the dampness but it has seemed to of got worse and I cant figure out where the water may be getting in from. I have inspected the felt roof as well and there are no problems there. Starting to get very frustrated with it
Just need some advice on where the water could be getting in from
Is the stack used? if its not used does it have a vented cap?
the chimney has never been in use for over 30 so Im not sure if previous owner had it capped. how will I know?? apologises my DIY skills arent the greatest
You can normally tell from the ground if the chimney pot has any form of cap on it.
If you are unsure post a pic.
I have had a look and the chimney is capped. All the flashing is ok and the repointing is good with no cracks and stuff in it.
