Hi can anyone help me please.
I could hear that I had a foreign object in the drain pump area so tried removing the fluff filter but it was jammed solid so I took off the drain pump from filter undoing one screw and turning it to release.
Found the object and removed it.
When I tried to put the pump back on I couldn't get all three lugs? to lock in place at the same time when I twisted the pump back on.
I noticed a rubber seal around the pump propeller which I removed and placed in to the fluff filter instead after which the pump connected very easily.
I now however have a leak where the pump joins the filter.
What's the solution?
