I got my HW cylinder replaced today as my old one was leaking.
That all went fine, the engineer noticed that my radiator in the hallway apparently had a very small leak, ie a few drips every now and then. He then removed my radiator and fitted a new valve on one side and the connected it back up.
The 'ends' of the radiator whatever they are, i believe the joint where the valve plugs in the radiator are leaking a few drops of water each, only very slowly but it's still a damn leak
What do I do about the problem, attempt to clean them up and solder around the joint area, even though this will make removal harder that will be a problem in the far future.
Or do I contact the engineer bloke and tell him, he's not obliged to do anything but will he
Regards
BW
Regards
BW
