The old toilet has been changed for a vanity unit.
There is a soil pipe adapter, very well fitted onto the old cast iron pipe which brings the diameter up to modern standards. This has a deep rubber connector aperture.
The soil pipe attaches about 2cm higher than the toilet outflow which makes it slightly uphill.
When fitted there was a slow leak from the standing water both at the connection to the toilet and at the connection to the adapter.
The toilet connection is unglazed, due to it being a vanity unit style.
I have been advised that upgrading the leaky Viva Slinky-Fit Flexible Pan Connector 200mm to a Macfit Flexible WC Connector Straight 160mm should prevent the leak at the toilet output as the Mac has a much tighter seal there. I am concerned about the connection to the soil pipe adapter.
It is unsuitable to raise the new toilet on a plinth.
Any technical advice?
