Hello, I have a mid-60s built bungalow that has a leak in the external water supply pipe (between the stop-cock & house). There is black plastic pipe running from the external stop-cock which is about 21mm diameter as best as I can tell, it joins to a 17mm black plastic pipe with a a brass compression fitting. Its the smaller of the pipes that is leaking just before it goes into this compression fitting. Once inside the house the pipe is back to 21mm again so presumably there is another underground joint that I have not uncovered yet.
Ive had a look on screwfix & the blue MDPE pipe & fittings are in 20mm & 25mm Im not sure what's compatible with what. Id like to replace the piece of 17mm pipe as presumably the other joint may fail as well, but what's the best thing for me to do?
