Hi there. To put a long story short, after a long process of elimination, I determined that the waste/drain pipe in my ensuite is leaking. The final experiment involved carefully pouring water down the shower drain. The trap is fine as it's always full. The draining water travels underneath the slated floor - the entire bathroom is slate by the way - and enters the main bedroom via the door - the only place we observe the results of the leak.
This is a new build block of flats (floors are concrete), so I'm unable to access the pipe from the floor below.
My question is, is it possible to more precisely identify the location of the leak (and ultimately seal it) without taking the bathroom apart?
Many thanks for your advice!
