leak inside boiler?
15 Sep 2010
Manchester
Good morning all.
Last night I heard a drip coming from the boiler (SIME ecomfort 30HE). There were no visible leaks externally.
About 4 months ago, I repaired an aquafilter leak with new gaskets, and assumed it was something to do with this, so took the cover off to inspect.
Nothing that i can see. No sign of water where it shouldnt be!
I can still hear this drip though. its DEFINITELEY coming from inside. I can only imagine its in the part of the boiler where the heat exchanger and gas burner live. My question is am I allowed to remove the cover to this part of the boiler to inspect for a leak, or does this have to be inspected by a gas safe engineer?
Better to be safe than sorry!
Matt
Could be a leak on the hot water side. Time to get a gassafe reg plumber or heating engineer in. ;) ;)
If the cover is not part of the combustion chamber, you can remove it. The M.I. will show you.
