Leak on new installed toilet
13 Aug 2006
Yorkshire
Hi i have just installed a new Toilet and has gone fairly well.
I have fitted a new straight w/c pan fitting which seems ok for height and
length, but my problem is a slight dribble when flushed.
Is there a product to seal this and stop the leak. Is it a common problem.
The leak is between the front rubber seal and pan conector.
Hope you can help.
Shappy
remove pan connector and check that rubber seal is sat correctly and refit (lube if necessery). Generally, pan connectors dont leak if they are pushed onto the pan properly.
