- Joined
- 20 Oct 2008
- Messages
- 4
- Reaction score
- 0
- Country
I moved into a rental recently which had a caravan type dishwasher in the kitchen between the sink and the space for the washing machine. I got my ex father in law to remove the small dishwasher and fit in my standard sized dishwasher. He did the joinery work one day and plumbed in my washing machine then came back to do the dishwasher another day. I have been advised by the previous tenant that she had problems with blockages and frequently had touse a plunger both in kitchen and at shower?
Anyway, noticed a small leak under the sink (Its a sink with separate small sink\drainer. Also noticed that the sink sometimes had a smell and that water came back up the sink when washing machine was on, or when draining water from one sink, water would come into other sink. had a look under sink and lots of copper pipes and plastic ones that seem a bit loose.
Anyway mentioned this to my father in law when he came back to plumb in dishwasher. he mentioned the washing machine pipe didn't have a fixing at end to attach to pipe but he doesn't appreciate input when you ask him for help so I left him to everything. he said he tightened up a Y joint that had nothing going into it and said that should fix my leak. He is now back home to South Africa for the summer over there and I am now having to drain my washing machine into a bucket as otherwise it goes all over the parquet flooring (didn't do this initially), and there is still an occasional leak in the cupboard. I have had a look below but cannot see where the other leak is coming from. I notice the dishwasher - the nearest one to sinks waste is connected into a pipe which is sealed at connection, whereas the washing machine was going into a tall wide pipe. Also the sink sometimes drains slow so I plunge it regularly.
I am guessing I may eliminate my problems if I can get the washing machine (which I guess pumps out more water) into the sealed waste pipe (I gather swapping out waste pipes between washing machine and dishwasher would do the trick if it stretches that far?), and that the tall pipe (standing pipe?) should be able to cope with the dishwasher waste?
For info, I never notice a leak when dishwasher is on, just when using sink and with the washing machine draining into the tall pipe. As my father in law has done some work and my funds are tight- single mum with an ex abroad and a 2 and 3 year old to look after (and a third birthday to plan for youngest on 11th of next month!) I want to try and fix this without involving landlord as she will probably say I am responsible due to work my father in law did and it was difficult enough finding a landlord who would take someone on housing benefit.
Also should I try buying that sink and plughole unblocker to see if it will clear out drains\pipes? I have only been in this house 1 month....and i know that corners may have been cut in past due to strange socket and switch installs -sideways\upside down\strange locations etc....
Thanks in advance again as this is 3rd question I have asked on these forums tonight
