Leak
28 Apr 2006
Tyne and Wear
I have a Mira 415 shower. Water is leaking somewhere and appearing under one corner of the (ceramic) shower tray. I have regrouted the tiles and sealed the area where the tiles meet the tray but it still leaks when the shower is on. I am wondering if water is leaking where the pipework enters the shower through the wall. Is it a do-it-yourself job to disconnect the two inlet pipes and look?
Tom
The problem with do-it-yourselfers is they cannot see reason.
First you say it only leaks when the shower is on. Then you say is it the connections on the back :LOL:
Assuming the shower controls are at the front then the leak must also be at the front or it would leak all the time.
Dam I hear you say that means the tiles are still leaking :rolleyes:
The tray.......leaks when the shower is on..........The poster questions could water be leaking from hidden connections in the wall :?: and is it a job he could do........Yes it is , the front of the shower control will disassemble and reveal the water connections which you can then tell if they are leaking Some people just understand better than others ;) :LOL:
