Leaking basin tap
that will be a allen grub screw.
unscrew the lever on the front check in the bottom of the hole.
you'll need a small allen key.
it'll be the cartridge leaking anyway.
I removed the handle, tightened the grub screw inside as tight as I possibly could and it's still leaking.
Also, tried removing the grub screw to see if the top of the tap would come off but it won't. I've now tightened up the grub screw so much that I can't undo it.
Oooohh, you've gone and done it now, call a plumber and see if hes up for a challenge. ;)
What exactly is the grub screw supposed to tighten/untighten?
