Hi All,
Looking for a bit of advice. I have just moved house and the bath overflow leaks (found this out by waterfall in kitchen).
The overflow is a rounded knob that twists to pop-up the plug. The overflow is very loose and I can not detach it. The is a hole in the side of the overflow knob with a screw inside that I assume I need to to remove to get the overflow off. This screw looks like a hex screw and has corroded badly. I can't remove it even with WD40 and am afraid that the screw head is trashed now with all my attempts.
Would it be possible to use something like gripfill to hold the overflow in place with a sealant on top?
Cheers
Cheers
